a6965921 Posted June 15, 2011 Share Posted June 15, 2011 how to use houdini to make water link for example 2 Quote Link to comment Share on other sites More sharing options...
Marc Posted June 15, 2011 Share Posted June 15, 2011 There's a thread on the SESI forum that explains how that kind of effect is done. It's fairly tricky but that thread should point you in the right direction. Just search for 'ink' (I think ). M Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted June 15, 2011 Share Posted June 15, 2011 advecting particles using a low res smoke sim?? render out particles as points using a delayed load procedural..or probably use ClusterThis dso.. ClusterThis Quote Link to comment Share on other sites More sharing options...
a6965921 Posted June 16, 2011 Author Share Posted June 16, 2011 who have tuturial Quote Link to comment Share on other sites More sharing options...
olegwer Posted June 22, 2011 Share Posted June 22, 2011 This is making of. All work has been done in 3ds max and ae. Quote Link to comment Share on other sites More sharing options...
old school Posted June 25, 2011 Share Posted June 25, 2011 wha? I counted 6 software packages including plug-ins and one kick-ass CG artist including a home-made ink fluid tank. I put 95% of the success of this shot behind that kick-ass CG artist. Software was just a tool as it should be. So in Houdini, yes advect points in velocity fields generated out of DOPs. There's even an Advect POP tool to set this up for you easily. See the attached hip file for one simple scene that pushes a box through a field then uses those vel fields to advect particles. advect_particles_falling_rbd_box_steps.zip Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted June 25, 2011 Share Posted June 25, 2011 Clearly a talented artist, but I think he could have simplified and streamlined his pipeline ... procedurally. Quote Link to comment Share on other sites More sharing options...
