H12 unwrap uv edit uv problems
  • Please log in to reply
4 replies to this topic
#1 sanlin
sanlin
    Peon
  • Members
  • Pip
  • 21 posts
  • Name:Shandy Pranoto
Posted 04 July 2012 - 09:47 PM
Hi guys,
i just installed houdini apprentice latest build in a new machine in the office, but when i am using it, and about to unwrap uv and then edit uv, i cant use the transform gizmo in the edit uv node.
So everytime i want to move vertex, normally i add edit uv node, and then from there on i will use the transform gizmo to edit my uv. But this time, when i click at the gizmo, it just vanished, so i cant rotate even or scaling them. If i want to move my vertices, i have to click right on top of the highlighted vertices, if i click on the gizmo, again it will just vanish.
i found this is a bit odd as it should be okay.. i did unwrap uv in houdini several times but never bump into anything like this.
any help would be appreciated.
Thanks,
Shandy
#2 gui
gui
    Initiate
  • Members
  • PipPip
  • 114 posts
  • Name:Guilherme Casagrandi
Posted 07 July 2012 - 04:54 PM
I have the same problem and I think it's opengl related. Try changing the opengl version in preferences->3d viewports.
#3 sanlin
sanlin
    Peon
  • Members
  • Pip
  • 21 posts
Posted 08 July 2012 - 07:38 PM
yeah thanks!! yeah i tried changing those as well back to H11 and also i notice that the face normals is not facing the right direction so maybe it affects the gizmo in uv editor.
so i did these two steps and so far it is working...
that is weird because the graphic card is geforce gtx 580 3gb DDR 5...
#4 kiko
kiko
    Peon
  • Members
  • Pip
  • 6 posts
  • Name:Kirill Kovalevskiy
Posted 22 October 2012 - 06:20 AM
Thank you guys!
#5 malexander
malexander
    Illusionist
  • Members
  • PipPipPip
  • 366 posts
  • Name:Mark Alexander
Posted 22 October 2012 - 08:51 AM
This was fixed in 12.1.85.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
