seifdune
Members
  • Content count
    9
  • Donations
    0.00 CAD
  • Joined
  • Last visited
Community Reputation
0 Neutral
About seifdune
  • Rank
    Peon
Personal Information
  • Name
    seif dune
  • Location
    tanzania
  1. Houdini 17 Wishlist
    animation tools: motion path which allow to direct tweak curve in view port for better animation arc, improve view port perfomance because when enabling onion skinning the perfomance become very slow, drawing tools like doodle. rigging tools: autorig with facial controls. modeling tools: bridge tool improvement the current workflow of selecting the source edge/polygon and the selecting the destination edge/polygon it's real boring and time consuming, hope the improve this by allowing selecting both edge/polygon and apply bridge. edge loop tool need improvement to allow symmetry adding two edge direct to the conner of the object, this will increase speed in modeling process like modo loop slice has many functions (symmetry ,free, uniform). grooming: improve the perfomance when applying the hair gen it's like simulating ocean on my laptop the perfomance become very slow. due to this it's real hard to make grooming process hope the sideFX improve the perfomance of hair and fur tools.
  2. animation motion path
    how to add motion path in view port during animation in houdini, motion path allow animator to edit the animation curve direct in the view port.
  3. how to change stepped keyframes to spline in houdini
  4. look at
    Am following old tutorial to create system where one object aim to another object but in this tutorial they are using null and has option of look at. but null in houdini 16 does'nt has one how can i create the look at,please help me.
  5. cracking effect
    "do a shatter geo like in the sidefx tutorial, then pack them based on connectivity" how to pack using connectivity sorry i didn't understood, please explain to me.
  6. exporting animation problem
    my digital asset seifdune_queen.hda
  7. exporting animation problem
    i just created animation using digital asset inside houdini 16. But i want to export animation to another package using (fbx or alembic). i keep getting weird result when exporting this animation in alembic some geometry jump to another position and fbx missing part of the asset.Please can you check this file and help me if there is any problem. chibanimation.hip
  8. i keep getting watermark when using arnold on linux other program like nuke running without any problem. i tried to follow different solution but i can't solve this problem until now. many say the problem is rlm because the foundry program use the same port with arnold and cause conflicts. how to create environment variable on linux(i want to create one for arnold) and how to set up a license server.
  9. cracking effect
    how to create cracking effect using boolean. I want to create cracking effect which demonstrate the explosion of diamond starting with cracking and explode.
