adding render control (start, end frame, step) to otl
katisss
The Start/End/Inc parameter is of Type: "Float" and of Size: "3".
You can inspect the Start/End/Inc parameter on any Render Node by RMB (Right Mouse Button) on the node icon to get the node menu and from there select the very last option "Type Properties...". From the Edit Op Type Properties dialog, just select the Start/End/Inc (f) parm to see how it is set up and copy it.
