Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
shareu
Creating simple tornado motion using pointcloud
37 posts in this topic
I used to make tornado motion with pointcloud. I was helped so much from odforce. This time I hope to be helpful to have the opportunity. Hope you likt it. Ian Farnsworth,Igor Igor Zanic~
tornado_v01.hip
tornado_v01.mov
Edited by shareu
8 people like this
Share this post
Link to post
looks awesome !
i like it very much and thanks for sharing , because you are helping me too to understand some things .
.cheers
1 person likes this
Share this post
Link to post
I couldn't help not use this file for testing the volume plug-in I'm working on.
I won't cross threads but just wanted to say it's a good one for benchmarks.
Thanks.
Share this post
Link to post
Very nice setup. Thanks for sharing guys ! :D
Edited by md5
1 person likes this
Share this post
Link to post
So interesting...both setups!
Bunker, I was checking your scene and the visualization coming from the DOP network is really cool even in OpenGL!! :huh: So I tried to cache this somehow, but when I used an DOP I/O I realized I needed to multiply the density 10 times (I used a Volume Mix for this, not sure if there´s a faster way...this one works) to match your visualization parameters in the smoke dobject.
My question being....in order to render a scene like this, would you just cache that and throw in a volume shader? I´m bettin it can´t be that difficult to get it looking nice, considering how good it looks in Open GL already! :)
EDIT: Yup. I just did it...well, with one small frame because my computer is too old to render volumes, but it does work....
EDIT2: ummm...bunker, why is it that as the point cloud lifts higher your volume clouds looses density? did you check it? it doesn´t look right to me. The original point cloud does loose a bit of point density, but not as much. Looks to me like there´s some volume-related problem there...
Edited by Netvudu
Share this post
Link to post
Great stuff guys, I have learnt so much from your examples. Now I have 2 questions :)
shareu: Why did you used the point cloud instead of just global node with P and stuff?
bunker: Why the density starts to fade off after certain point?
thanks!
Also my example using similar (not identical) setup:
http://vimeo.com/27582239
Edited by chimeric
Share this post
Link to post
can I ask why do I get nothing when I render scene v.2?
Edited by SMVFXART
Share this post
Link to post
pretty cool setup bunker, i modified it a bit and got this!
Hey ikarus,
What changes did you make to bunker's scene file? can you upload it? yours looks very different!
Edited by R_cyph
Share this post
Link to post
tornado_v02.hip
Sorry for this up, but I want to advect fluid in particle and the example of Bunker is what I would like to do.
I'm in Houdini 12 and Smoke solver is different from Bunker's version.
Could you help me to make the same effect as Bunker?
I already have a begin of result, but I don't have the same result as Bunker.
Edited by Kevju
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
