oldiesgoodies Posted June 30, 2011 Share Posted June 30, 2011 (edited) Hi I create a grid and turn into smoke by using the smoke from object. Then I create a sphere and turn into smoke by using the smoke from object tool adding to the same fluid domain(only the sphere is there). Now what happens is that the grid is not in the smoke domain anymore. It seems like only one object is enabled in a fluid domain? Does it make sense? I am trying to make these 2 objects interact with eachother pretty much thanks Edited June 30, 2011 by oldiesgoodies Quote Link to comment Share on other sites More sharing options...
anim Posted June 30, 2011 Share Posted June 30, 2011 use Source From Volume/Surface/Points shelf tools instead (or merge your objects into one, then use Smoke From Object) Quote Link to comment Share on other sites More sharing options...
