How do I connect curves
DELTAadmin
Dear Houdini users
Could u help me? How do I connect two separate curves which later I want to handle as if they were one. I want to connect the endpoint of the first one to the starting pont of the second one, weld these points and make the curve closed. I could do it in Adobe Illustrator (not a procedural system), but I think it is a simple task Houdini should handle. Later I want to extrude this curve. Also it is a basic task in Cinema 4D.
The merge op is not sufficient, their points should be welded or more points added if needed.
Thanx
