Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
poppy
FLIP smorganic/sheeter effect?
84 posts in this topic
There's no fluid software in the market capable to do this effect. CIS Fusion have a great solution, but is not ever close to ideal, since it looks like there's no concern to volume preservation and correct surface tension. The paper that Skybar posted is the best solution so far to flip method, but it relies on a anisotropic meshing system (flat spheres instead of spherical ones), which is currently not supported by OpenVDB or any other software.
Share this post
Link to post
Is there a way to achieve this effect in H?
https://vimeo.com/12992186
http://www.fusioncis..._smorganic.html
Currently I'm working on a fast and stable solution to this limitation, I'll sold the asset in Orbolt very soon (I'm working on the promo video ;)).
Here is a little example (comparison) of my aeb_FLIP_sheets asset. This test was executed with the solver default settings and a small amount of particles, to ensure that my asset work even at very low resolutions, in this scenarios is like a localized up-rez technique.
post-3275-0-81564700-1375062075_thumb.jp
post-3275-0-22361300-1375062100_thumb.jp
Edited by Pazuzu
2 people like this
Share this post
Link to post
Here is a little example (comparison) of my aeb_FLIP_sheets asset. These tests were executed with the solver default settings and a small amount of particles, to ensure that my asset work even at very low resolutions, in this scenarios is like a localized up-rez technique.
http://speedy.sh/ASJ...ts-examples.rar
The download doesn't seem to work for os X. Any other way to share it?
Share this post
Link to post
Sorry for that, (this time are Quicktime files) but here is another test.
The sheet_tendrils video, forces the tendrils and fills the holes in a more agressive way.
sheets.mov
sheets_tendrils.mov
same_sim_without_asset.mov
Edited by Pazuzu
2 people like this
Share this post
Link to post
Mark at Fusion CI Studios came up with the workflow originally. There's a plugin for it now in RealFlow and has been for a couple versions. It's called the sheeter daemon. True, it's not physically accurate but in order to simulate thin sheets and preserve volume it would take a lot of particles (probably billions). Faking it is the only practical solution for now.
Share this post
Link to post
Thats very cool. Can't wait to try it!
Share this post
Link to post
Here is another example, this time without gravity and a more subtle threshold for the hole filling.
More examples to come!!!
sheets_03.mp4.rar
3 people like this
Share this post
Link to post
looks really cool!!
can't wait to see more examples :)
I recall seeing an anisotropic meshing mode from the Thinkbox Frost website, although I'm not sure if it's the same anisotropic meshing method mentioned in the paper posted by skybar.
Share this post
Link to post
Implementation of anisotropic method is quite simple, I made one https://github.com/mishurov/anisotropy_matrix But since Houdini uses OpenVDB for surfacing the FLIP, therefore OpenVDB developers should add that algorithm into their library. And there are some perfomance issues to use fastest method for calculation of Single Value Decomposition and so on.
2 people like this
Share this post
Link to post
This achieves with better surface tension calculation what nodes like the sheeter daemon achieve with particle reseeding:
Versatile Surface Tension and Adhesion for SPH Fluids
http://cg.informatik.uni-freiburg.de/publications/siggraphasia2013/2013_SIGGRAPHASIA_surface_tension_adhesion.pdf
http://cg.informatik.uni-freiburg.de/movies/siggraphasia2013/sigasia13_video.mp4
http://cg.informatik.uni-freiburg.de/people/nakinci.htm
2 people like this
Share this post
Link to post
Impressive!  Will be great to have this as part of the Houdini liquid FX arsenal!!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
