krautsourced Posted October 17, 2013 Share Posted October 17, 2013 So, for a small project I was planning to try out the still hidden (as of 12.5.550) DOP POP nodes. After I opunhide'd all of them, I tried the simplest possible thing: I created a DOP network and dropped a POP Location node in. However, nothing happens. Am I missing some hidden option here somewhere to turn the POP integration on? What would be the correct setup to use these new nodes (apart from waiting for the H13 release ) Cheers Michael Quote Link to comment Share on other sites More sharing options...
Zach Posted October 17, 2013 Share Posted October 17, 2013 Welp, you need a Pop Object to attach the particle data to, and a Pop Integrator (also hidden) to do the magic. Pop Object in the left input, Pop Location into the right... you should be set! Quote Link to comment Share on other sites More sharing options...
krautsourced Posted October 17, 2013 Author Share Posted October 17, 2013 (edited) Aha! Thanks man, I totally did not get that I had to feed a POP Object into the first input! Edit: well, this is pretty awesome indeed! All the more reason to look forward to H13.... Edited October 17, 2013 by krautsourced Quote Link to comment Share on other sites More sharing options...
