how to render correct 2d motion vector for Fur object
I learn that 2d motion vector Nuke use is different from RSMB, it is something like projection, for example, I have a point move from posA to posB during 1 frame, so project the point use ray from real world to camera screen like the picture below, so it is different, I want to know how to write this shader?
post-9044-0-96233100-1386376918_thumb.jp
And the image below is what I search in forum, this is wrong when I render 2d motion vector for my fur object. Now I want to render read 2D motion vector for my fur layer, anyone know? Thanks a lot. :D
post-9044-0-24076200-1386376921_thumb.jp
Hmm, actually the same settings I use for curve (fur) rendering with motion vectors and had no problem. Maybe for very fine hair you need more pixel samples and geo/xform samples or try exporting the motion vectors image plane with no filtering.
Try this one, Actually for the fur to work, You need to increase the geo samples (as you already noticed) to something greater than the default value of 1.
Yes, it works, thank you, but what is the different between Bind and Parameter when I export a channel to extra plane in shader?
Bind vops introduced in H12 or H12.5 and they supposedly have a faster evaluation than the old Parameter node. Actually I've never compare them in such a way to notice any speed difference, but I like bind nodes because they are much faster to set up as there are 2 options to choose when you hit the tab key: Bind and Bind export (it's actually the same node with different settings for importing or exporting an attribute).
Ok, ic, thanks again!
having a look at the reelsmart motion blur requirements today. seems the output from the above shader are not what RSMB wants.
http://help.revision...1/#/tutorial-88
houdini outputs with no motion at 0.
rsmb requires no motion to be a value of 0.5
next,
this shader can result in any value, but rsmb values must rest between -1 0 1
so, all values in a rsmb motion vector pass must be normalized from -1 0 1
finally,
resultant must mapped -max to max from 0 to 1
anyone know how to adjust the network to accommodate rsmb motionVectors pass output?
lastly,
in the attached jpg, there is a problem in the value output for vertical versus horizontal. given same motion, those values should be equal regardless of direction.
rsmb_h12.zip
post-7263-0-50099400-1386729508_thumb.jp
Edited by moondeer
I also wanna correct the previous posts I made. Thanks to Eric who pointed this out, the Transform vops (current space to NDC) are not needed (that's why it was exporting different values in X and Y). Houdini just converts everything in shaders to camera space by default. So, as NDC is normalised to the output frame ratio, it's not appropriate for exporting accurate motion vectors. Here I ' ve attached a hip with the fixed shader and a Nuke script with a direct comparison between the old shader and the new one without the space transform vops.
moVecTests.rar
Edited by Sifis
