How to change all texture paths to different location easily?
avak
Hello
currently  I (working on windows) received some fbx model from other artist (linux), all these models have many many details ,say each model contains hundreds of small pieces and each piece has a material with a texture and the path of texture is a unix format,
when I import these fbx models to houdini, no texture I have and I am on windows, ...really could not find a solution to change the path of all these textures the way my houdini on windows can find it,...
 here is an example of one texture path of the model I received:
/media/data/proj/int/Dec2013/seq1/assets/stand_rig/Met_Yelw.bmp
and I want to change it to something relative:
$HIP/textures/Met_Yelw.bmp
easy for one texture  but I have as I said hundreds of these to change
hope you help and thanks in advance
Edited by avak
Have you tested opchange hscript?
Try open hscript textport, and type follow.
opchange /media/data/proj/int/Dec2013/seq1/assets/stand_rig \$HIP/textures
It might help you. But if you think something go wrong, just Ctrl-z or don't save file and quit.
* sorry, I miss spelled textures -> textrues, I corrected it.
Edited by yongbin
It would be great to have a tool that lists and allows editing of all the external references of a scene, objects, textures, caches… Something I miss from Softimage...
'Pre-Flight Scene' has some of this under the Render menu
  • 1 year later...
Thanks for the tip, I have one doubt, I dragged all textures to hip file (Green) area. All textures copied to the location but in shop texture path remains unchanged did i miss any thing?
Edited by Sankar Kumar
