export OTL handle from it's inside polyextrude node.
Hi, I have a question about an otl handle.
I want get the handle from it's inside polyextrude node.
But I don't know how can I export it. I manually made handle and mapping to polyextrude node (from Type Property > handles) . but it appears in a wrong place.
Is there any good method for this?
I will upload my scene. Thank you!
hairfarm.hipnc
My guess is that you don't have all the required parameters promoted. Try this:
- Open up the Type Properties for your HDA and switch to the Parameters tab
- Now dive inside and invoke the PolyExtrude handle by clicking on the node and then hitting Enter with your mouse in the viewport
- Right-click on the handle and choose "Export Handle to Digital Asset". This will promote all those parameters from scratch and attach them to the handle.
Hi, edward. :)
That works like a charm. Thank you very much for your help!
I tried this before, but my fault is that I didn't open type property window when I export handle to digital asset. Even I notice there is a warn window for that!! shame on me.  :blush:
Thank you again!
Edited by yongbin
