Guest mantragora
Guest mantragora
... doesn't work with my custom OTLs?
When I create "null.py" it gets called, but when I create python file with my OTL operator type as name, it's ignored. Should I put it in different place than for normal nodes?
Thanks!
Edited by mantragora
Guest mantragora
Well, when I created "explodedview.py" it was also ignored, so that means that for OTL script should be placed in different location than for normal SOP.
I tried to create "otls" folder in "scripts" and in "scripts/sop" folder and then put initialization script there, but it was also ignored.
Anyone?
Guest mantragora
Well, you're really letting the oxygen out of my tank here! :(
I'm in the process of fixing some old tools and I wanted to use CreationScript instead of PreFirstCreate event in OTL to add selectors and manage couple other things.
Any other advice?
Thanks.
