shading starter question # 1
gaurav
Hi Guys,
I am intersted in finding out how much of illuminance (that is integrated luminance over the hemisphere) is scaled on a point being shaded by a given BRDF function.
Is it possible to grab this value at shading time. I find terminology /units of photomery and radiometry rather confusing in the begining and just wanted check my understanding. :unsure:
Thanks,
-Gaurav
Thanks eetu,
seems default surface model vop has it (albido- [diffuse+glossy]) exported as "direct_reflectivity".
Which by no surpirse is the sum of diffuse + specular intensities parms.
But if i get it right, the BRDF depends on incoming and outgoing direction and gives the relative distribution of scattered and reflected light over all outgoing directions.
Now on a humble [diffuse and reflective] sphere i would expect to see varying values returned by specifc BRDF function by which all the incoming radiance (direct + indirect)to a point on its surface are scaled. which i dont find in the direct_reflectivity aov.
I am new to these highfalutin terms to extent of not even being sure what i am asking makes sense ;) with that said here is my second question :
2. Does Physically Based Diffuse vop implements standard lambertian model ?
Thanks,
-Gaurav
