Any idea what this error log means?
I created a custom SOP. Sometimes I can cook it successfully, other times it segfaults. It seems to always segfault after the "cookMySop()" function completes (i.e., outside of the code that I wrote???). When it segfaults, it either gives me one of two error logs, or no error log at all.
Here are the two error logs. Can anyone make sense of them and direct me in a direction that I can start to look to debug this?
Log version 1:
Caught signal 11
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
[0xf70e] <libpthread.so.0>
UT_StringArray::entries() const <libHoudiniUT.so>
GT_AttributeMap::GT_AttributeMap(GT_AttributeMap const&) <libHoudiniGEO.so>
GT_AttributeList::addAttribute(char const*, UT_IntrusivePtr<GT_DataArray> const&, bool) const <libHoudiniGEO.so>
GT_PrimVolume::getPointPrimitive() <libHoudiniGEO.so>
GR_PrimVolume::update(RE_Render*, UT_IntrusivePtr<GT_Primitive> const&, GR_UpdateParms const&) <libHoudiniAPPS3.so>
GUI_GeoRender::updatePrimitives(RE_Render*, GR_DisplayOption*, UT_Array<UT_IntrusivePtr<GT_Primitive> >&, GT_RefineParms&, GR_UpdateReason, GR_DecorationOverride, char const*) <libHoudiniAPPS3.so>
GUI_GeoRender::update(RE_Render*, GR_DisplayOption*, GUI_SetupResult, GR_DecorationOverride, char const*, bool&) <libHoudiniAPPS3.so>
GUI_DetailLook::updateForRender(RE_Render*, GUI_DisplayOption&, RE_LightList*, GR_DecorationOverride, char const*, bool&) <libHoudiniAPPS3.so>
DM_VPortAgent3D::setupGeometry(RE_Render*) <libHoudiniAPPS3.so>
DM_VPortAgent3D::renderViewport(RE_Render*, int, int, bool, bool) <libHoudiniAPPS3.so>
DM_VPortAgent3D::doRender(RE_Render*, int, int) <libHoudiniAPPS3.so>
DM_Viewport::doRender(RE_Render*, int, int) <libHoudiniAPPS3.so>
UI_Feel::renderMe(RE_Render*, int, int) <libHoudiniUI.so>
UI_Feel::doRenderKids(RE_Render*, int, int) <libHoudiniUI.so>
UI_Feel::doRender(RE_Render*, int, int) <libHoudiniUI.so>
UI_Viewport::reRender(RE_Render*, bool) <libHoudiniUI.so>
UI_Window::renderChildViews(RE_Render*) <libHoudiniUI.so>
UI_Window::doRedraw() <libHoudiniUI.so>
UI_Queue::doWindowRedraws() <libHoudiniUI.so>
UI_Queue::processNextEvent() <libHoudiniUI.so>
UI_Queue::drain() <libHoudiniUI.so>
UI_Queue::eventLoop() <libHoudiniUI.so>
main_part2(int, char const* const*) <libHoudiniUI.so>
main <libHoudiniUI.so>
[0x1ed1b] <libc.so.6>
_start <houdini-bin>
Log version 2:
Caught signal 11
RE_TextureFont::getGlyphInfo(unsigned int) <libHoudiniUI.so>
RE_TextureFont::getStringWidth(unsigned char const*, unsigned char const*, UT_Unicode::transform const*) <libHoudiniUI.so>
SI_DopeSheet::renderFrameIndex(RE_Render*, float, float, int, int, int, int, double) <libHoudiniUI.so>
SI_DopeSheet::renderFrameIndicator(RE_Render*, int, int, float, float) <libHoudiniUI.so>
SI_DopeSheet::doRender(RE_Render*, int, int) <libHoudiniUI.so>
UI_Window::doRender(RE_Render*, int, int) <libHoudiniUI.so>
Load Houdini with valgrind (I think it's mentioned in the HDK docs) with your test scene. Ignore all the messages it gives you except for the ones in your own code. Make sure you compile your plugin with the -g option so that debugging information is provided.
