pyro Flames and emission
gigafrax
Hello fellow houdini users.
First of all i whish you all a happy Newton's birthday (one day late, sorry) and a great new year!.
I need your help about pyro and flames: my first problem is to create an emitter sop that behaves like the attached clip. I want the flames to be generated, expand a little bit as if they were consuming a large drop of alchohol (or any other burning liquid) and then disappear when the fluid runs out.
I tried to scatter some points on a surface and then controlling the emission color using a turbulent noise in a vopsop, with the offset animated, but it is not controllable enough.
Also i will appreciate any suggestion about shading and simulating pyro flames which looked like the reference picture attached, i looked around but apparently there are not many tutorials about flames and pyro. (i might be wrong)
Thanks all in advance for your help!
Francesco
emissionSource.mov
post-11876-0-60542500-1419599149_thumb.j
