Extracting force fields generated by microsolvers
Hi Guys,
Missing some basics here..
I want to be able to Visualize force vector field from, lets say  Gas Vorticle Forces (using vector field viz) and Modify ( gasfield vop/wrangle) it pre solving step.
How do I go about doing it ?
Thanks,
-GM
Edited by gaurav
Gas vorticle forces usually directly changes the velocity field.  So if you want to visualize it and change it you'll need to create a separate vector field (which you can attach a vector volume viz to) and apply the vorticle forces to that custom field.  Then you can do whatever modifications to that intermediate field and add it to the velocity field.  If you have resizing volumes you can just use a gas match field referencing the velocity volume (you can also apply a vector volume viz to this as well).
