where is Impact gone?
Hi. Everybody.
I met a problem when change the H13 file to H14.
There is simple flipobjec collide with rbd object, the h13 list a detailed Impact data in detail view, but after open with h14, it just lost.
If i want fetch them in sopsolver or Impact to attribute, how can i built it. impactanalysis seems not for flipobject.
I try to search them in flipsolver and find any different between H13 and H14,  failed.
Any help will be great.
Thanks.
post-9982-0-51345200-1432363328_thumb.pn
untitled.hipnc
For speed they are off by default:
Check this:
https://www.sidefx.com/index.php?option=com_journal&Itemid=213&page=index&journal=default&view=FULL&logfile=ALL&icon=ALL&version=ALL&buildstart=184&buildend=184&perpage=20&search=Add+Impacts+Data&find=Find
It needs to be turned on inside FLIP solver on integrate_particles node and probably also on popsolver1 node.
Check this:
Thanks , Zloty.
When turn Impact data on, it comes back again.
I totally miss it before.  :)
And you teach me a great way to find any change between different Houdini version.
Edited by wateryfield
