Particle separation flip fluids
vishalvfx
Hey everyone,
Trying to wrap my head around flip simulations in Houdini, any help is much appreciated.
so here is a animation of the sark i downloaded from the very talented Carlos Parmentier, (thank you)
My container is 50x25x55,
The rest of the setting are explicitely mentioned in the attached QT,  please do take a look.
So here are my questions,
1) as we reduce the particle separation, (increase resolution) the simulation changes quite drastically, so say if i were to test a sim at .2 separation, how do you know what you are going to get at say .075,
2) Is there any way to up rez these simulations without such a drastic change in the look of the sim.
3) I'm sure some of you masters in flip sim, could critique my simulation, and guide me to better them .
4) Other than the shelf tool for a white water sim, what would be the best way to get some white water?
Thank you.
one classical approach is to divide in 2 steps.
you make a low rez sim where you devise the global behavior , then you use this low rez sim to drive an high rez one.
this is the global principle
http://www.cs.ubc.ca/~rbridson/docs/nielsen-siggraph2011-guidedfluid.pdf
i have never done that myself in H but i'm quite sure the workflow can work smoothly in H.
of course you will have to burn some brain cell to make it work ... :)
maybe it has already been done here ?
Edited by sebkaine
