Copy ramp in VOPSOP
To do it manually...
Select the node you want to copy the Ramp to, then shift select the node you want to copy it from. Now on the node with the ramp you want, "jiggle" each handle slightly...you just need to nudge the values a touch and then put it back. Nudging one of the points triggers the other selected node to make a point there too.
The whole Houdini ramp business needs some love from SESI badly.
  • Like 2
  • 3 months later...
  • 1 year later...
