calculate distance between two specific points with VEX
jon3de
Hello,
My goal is to calculate the distance between two specific points in a wrangle sop. For the distance expression I need two vectors right? But I was not able to get the specific position vector of Ptnum 2 for example. After some research I was able to achieve it in vops with import point attribute.
In the wrangle sop I have still problems. Here I would be grateful for some help.
As you can see in the picture I try to create two vectors with "pointattrib" which I want to use in the distance expression. I think that is the right way but I have problems with the syntax of the "pointattrib".
kind regards
Jon
post-12840-0-39478800-1452350201_thumb.j
post-12840-0-94235500-1452350201_thumb.j
