I'm trying to learn, but I sometimes find it hard to get answers from the doc (real good doc tho).
here is what I'm struggling with at the moment:
I want the pivot of a transform node to to be placed relatively to another object (in the same geo node).
I need the pivot to be at XMIN in x axis, 0 in y axis, ZMIN in z axis.  Easy. But I need the XMIN and ZMIN of another object.
Can someone help me with the syntax ?
thanks !
Edited by 6ril
here is a hip file to make it easier.
I wrote:
XMIN of box1
to show you want I need, in the transform node.
I need help with the syntax.
something like that ?  op:"../box1"($XMIN)
*edit*
Or is it not possible this way because the help says: $XMIN is the min on x of the node input ?
XMIN.hipnc
Edited by 6ril
