emit multiple Packed Primitive with Constraints
kidsreturnjj
I'm trying to emit Packed primitive with Constraint.
Simulation seems work
BUT when I turn on guide of Constraint, constraint positions are out of object.
How can I keep constraint in side of each objects?
Thank you for you guys help.
12968043_10156779233870187_6070495958053
Edited by kidsreturnjj
you need to make sure your constraints are in rest pose of the packed pieces, not in their copied positions
look at the file, added nodes are green
I as well checked Solve on Creation Frame on your rbdpackedobject1 as the first piece was not added due to that (since it's being created on 1st frame)
multpleConstraint_v01_fix.hip
  • Like 3
