Delete part of Volume Cache
wilson99
that could produce negative values, no?
i would do a volume wrangle:
	f@density *= 1-volumesample(1,0,v@P);
convert your box into a houdini volume (NOT A VDB) and plug it into input 2.  plug your smoke volume into input 1.
Edited by fathom
  • Like 2
It could but, for something like the example he was showing he would be fine. That said, volume wrangle would be much faster and would be a much better solution.
-Ryan
Edit: Good to see you around Miles!
Edited by rbowden
There is Volume Resize SOP for dense volumes that is really fast. You can fetch polygon bounding box to its second input to keep only volumes inside that box.
There is also VDB Clip for Sparse VDBs that does similar thing.
Wrangle method is good if you don't want to change your original volume's bbox.
  • Like 6
  • Thanks 1
  • 2 years later...
