Mantra shader emission issue
FR3D
It seems i cannot get the emission to work anymore when using a mantra shader or a material shader builder.
The object doesn't light up nor illuminate other object.
It works fine with principled shader tho.
The project i am working on needs object to evolve thru attributes from emitive to refractive
If anyone has a tip or a work around it would be apreciated
Thank
On 6/16/2016 at 0:44 PM, Hamp said:
Update to a newer build, emission was broken but is now fixed.
Thank you,
I am running v15.5.480
It seems the new builds have serious failure so i will wait a bit.
  • 1 month later...
  • 1 month later...
