Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Sign in to follow this
Followers 0
Diorn
Magnet Force Disintegration, Scale by Distance... troubles with next steps
Hello, this is my first post on OD force and one of my first attempts to use Houdini for a project at the office.
In short, the shot is about an ice structure that is supposed to assemble out of thin air from fractures and pieces as a character approaches it.
Now, the way i went about it with my very green houdini knowledge is after fracturing the ice model with voronoi fracture, i made it into an RBD and
got control over the assembly or dissasembly via a Metaball influencing the fractures with a Magnet Force.
The next steps of this FX, and where i got stuck is, i need the pieces that float away from the metaball to scale down to 0, and dissapear once they travel a certain distance from the metaball.
Another nice polishing feature i can't really understand how to do is so the smaller fractured pieces don't get a much larger velocity than the bigger pieces as they get influenced by the magnet force, at the moment they explode away much faster than the larger pieces.
I'd appreciate any help with these 2 issues, and bear in mind i'm quite at the start of the learning curve here but am enjoing the workflow so far!
Edited by Diorn
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
