[SOLVED]PolyExtrude Like Bevel Profile In Blender?
Atom
Hi All,
I have a font object and I want to extrude it using the shape of a curve to create a custom extrusion look. I have dropped down a curve and connected it to the second input of the PolyExtrude node but no matter how I move the points of the curve around, no useful extrusion is ever produced using this technique.Untitled-2.jpg
Is there a way to emulate Blenders method for profile beveling in Houdini?Untitled-1.jpg
ap_extrude_font_profile_issue.hipnc.hiplc
Edited by Atom
depending on what extrusion you're after, this method might not be what you need, or what you think it is.
Don't think of it as a "profile" of extrusion, it is a spine of extrusion, which is very different.
with the curve you can see in the picture, a profil would give you beveled font (like the 123 on the right), but the same curve used as a spine gives you the 123 on the left.
that's just to (try to) clarify the polyextrude node, now about how to recreate the profil beveling of blender or max, I would need to search too, so I'll let more advanced users help you.
Edited by 6ril
I seen the problem, and it makes me think that may be, you should build the side first, then cap.
Like a sweep of your profile along the font (un-extruded font), to get the sides. Then cap the front and back.
But, to be honest, after a quick test, the sweep is making me loose my nerves. It works, but there's some clean up to do on the font first.
I'm now curious to see if there's a clean way to do this in H.
  • 4 years later...
Am alone to think the Sidefx Polyextrude could be improved? Here, it was on a planar shape but  putting down a full complex networks to bevel pieces of a voronoid fractured relatively simple geo, gets me wonders.
I guess i missed something? And the custom curve profil input, i don't know but itùs realyl a fight for such a basic but essential operattion. Or am i unlucky with my with my model or so?
On 15/07/2016 at 1:07 AM, 6ril said:
that simple :D  cheers nico.
pbevelhave
