Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Atom
UVs along each hair strand?
Hi All,
Is there any way to have UVs travel along each hair strand using the fur system?
When I apply the UV color grid to my hair it does color the hair but I would like to see the checkboard pattern along each strand, not broadly spread across the entire wig.
Share this post
Link to post
This is a fur setup with a lot of sub nodes, where should I add the UV Texture node?
Share this post
Link to post
allow editing of content on fur node, dive in, find "fur" node and inside after "create_fur1"
you might try to cerate the UV on guides and then transfer them into fur strands, but I didnt test that
1 person likes this
Share this post
Link to post
and another option is to create the UV parameter inside the shopnet1 - guideshader
that should transfer it to individual hair strands as well, and should be faster
1 person likes this
Share this post
Link to post
The global t in hair shader is 0-1 along the hair. Open the hair shader and have a look at how the opacity ramp is applied.
Share this post
Link to post
Thanks for the feedback. Martin's node placement worked for me but I needed to use Face instead of Rows and Columns to achieve the look.
Now to test and see if it holds up under Redshift rendering...
Edited by Atom
Share this post
Link to post
Sorry for the vintage bump, I saw your post on the RS forums as well I was having the same problem. I was wondering how you managed to lock down the UV's on the hair?
I've tried throwing down a rest SOP on the HairGeo but it doesn't seem to work like it usually does.
Edited by Tex
Share this post
Link to post
I kind of gave up on this. I don't think Redshift supports what I was trying to do at this time and Mantra is not really an option for me.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
