Fade volume near object
vrman
6 hours ago, Juraj said:
in your volume VOP / volume wrangle you can compute distance to closest point in geometry and based on that multiply your density value.
You can use xyzdist() or nearpoint() functions.
Thanks , Could you please give me a hip file for volume vop example ?
Edited by vrman
6 hours ago, Shinjipierre said:
another way is to create a volume from your object, blur it and substract it using a volume wrangle or volume mix, whatever is faster on computation time :) (as xyzdist can get slow)
thanx great idea , could you tell me how can i do this via VEX ? i  cant get volume density from input 1 or 2 with this code prim(1,"density",0).
another question , when i try to blur my volume , it will goes into my objects, is this possible to pushing out my volume ? something similar to what peak sop do ?
Edited by vrman
