Od Force search engine empty result ?
Hi guys ,
Is it me or the search engine of od force has been change with the new design ?
Because i often enter simple entry which i know should give me some entries, but very often i get 0 result.
Thus i am now using google to search od force topics to get more accurate result, and i would like to know if i was the only one to notice this ?
Cheers
I have the same problem but only with multiple words and only when you use the search bar at the top right. When you do a search the website puts some "+" signs around your words, if you delete them, you will get the correct result.
Maybe an admin can have a look in the code to see where the problem come from ?
Some screen capture :
One word search
Multiple word search with the top right bar
Suppressing "+" make it work.
  • Like 2
This forum software has always had a problem with anything less than 4 characters. It used to tell you that, I guess they took that away?
There's not much I can do unfortunately, although I will take a look to see if I can dig anything up.
M
