Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
MOKANA
Unable to change Node Parameter for each frame
I am using the following code to change the scale parameter in a geometry node:
s = @scale;
if (s < 1)
 if ($FF >= ch("/obj/CONTROLS/Start_Frame_HV"))
  s = s + .25;
return s;
I am able to grab the value, evaluate it, add .25 to it, and it is reflected on the desired frame.
However, after the very first time, it will not add to it and it stays at .25 until scene completion.
I have tried referencing it via the ch("...") function but it always comes back with a recursion too deep error.
Up until it hits the desired frame, which is 24, the value remains at the desired value of 0. Then at frame 24 it is set to .25, so this tells me that this script is evaluated at every frame, or am I missing something? I am able to increment it from 0 to .25 at frame 24, but nothing after that.
Any guidance would be much appreciated
Share this post
Link to post
You don't need variable s at all.
Replace all occurrences of the variable s with @scale instead. After all, what are you returning s to anyway?
This is running in a wrangle, right?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
