rafaelmoco
Follow position and rotation in dynamics
Hi guys;
I'm a Cinema 4D user trying to migrate to Houdini. In the past days, I tried to replicate a very common o effect in Cinema 4D dynamics. In there, you can use follow position and follow rotation to try to restrain a dynamic object in your original orientation and position
I'm tried to replicate this in Houdini, but without success. Maybe I'm trying to figure out myself using the wrong tools, or searching for the wrong terms in Internet, but I still can't find a good solution
I made a video, showing the effect in C4D. It's very simple, but a fast way to fill volumes with objects, without any collision
Any thoughts?
Share this post
Link to post
Interesting question. Had a go, I'm sure there's a more efficient way of doing this.
Seems that Bullet fights hard against this problem; from what I've read it detects if shapes intersect at the start of a sim, it treats them as glued together, which is exactly what you're trying to avoid here.
At first I thought 'ah, I'll scale the shapes really small at first, or shrink their collision geo really small, and quickly expand to full size', but there doesn't appear to be a way to do this with Bullet either.
In the end I gave all the objects a starting velocity away from the origin, but then give them a force to try and attract them back to their starting position. This bit of jostling is enough to keep Bullet happy, and the shapes re-settle into a deintersected arrangement, more or less.
rbd_deintersect.hipnc
  • Like 2
Share this post
Link to post
Thanks for the help!
For sure, is a clever way to deal with this "problem". I didn't know bullet treated intersecting shapes as glued together.  Actually it's rings some bells for me in other problems I was having with simulations
Thanks again!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
