Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Sign in to follow this
Followers 0
shinsso
Why shadow color should be white?
when I rendered some smoke images, the smoke looked very flat even though I simulated high quality volume for long time.
The problem was that I changed shadow color to closed to black. The default is white.
I changed it back to white and rednered again. It looked much better.
Why the Shadow color is white? How does it work...?
Thanks.
Share this post
Link to post
there must be a mistake, the shadow color is by default black, white shadow color means no shadow.
Share this post
Link to post
sorry, I mean the shadow color in the Pyro Shader.
This following image is default Pyro shader.
I use Houdini 15.5
Edited by shinsso
Share this post
Link to post
In this instance the shadow colour is subtractive. E.g., if you have a (1,1,1) colour volume, what shadow colour should I use to subtract? To make a normal-colour shadow, you want to subtract white.
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
