how do you add cvex displacement alongside a volume procedural whilst instancing using the "instancefile" attr?
TomFX
Hi Guys
If anyone has done this and has a solution or any advice that would be great and hugely appreciated.
It is fairly easy to do all of this if your volumes to instance are within your hip scene. However once you are only referencing them from disk I am struggling to run the cvex over each instanced volume (of which I am using 20 different variations hence using the "instancefile" attr.) I am also trying to volume sample each instance to pull in surface, rest etc primitives into the cvex context to drive my displacement.
many thanks
tom
