Bullets Holes Effect, Help me to "Update" geometry in DOPS.
carlossa3d
Hi guys, this is my first topic , im setting the base of this effect, at the end of the nodes you can see that i divide my geometry in 2 groups, each one will set the geometry as an active object or a static one, but the geometry have to switch group in a frame basis. ( you can see this moving in the first 4 frames). the problem is that DOPS dont activate the new active geometry. sorry if im not giving enough details. but can you guys help me to fix this?
thanks for the help.
crack2.hipnc
