color picker not matching render result
9 hours ago, davpe said:
just guessing, but with such a small deviation like this (~0.0001) i would blame a sampling noise
thanks for your reply
i tried to fix it by reduce the noise in mantra rop but no successes, i just tested it in comp and i get the same result, is it a bug ?do you know any other tools than can pick a color from an image for houdini ?
hmm, I see. the workflow is interesting. i just tried this and found out color picker only has 8-bit color resolution so this may be it. colors in render are fine (color inspector show correct numbers) but picker seems to do a poor job. shame.
5 minutes ago, davpe said:
maybe, but this is something I wouldn't know how to approach. you need someone smarter to help :)
no problem dude you are smarter then me XD . another thing when i change my render pass to 8bit integer this little value pop up in the inspector if i can find a way to pick it it will solve my problem
I believe the value is 0.2627 * 255 = 66.9885 (or as an integer 67).
I also played around the settings a bit, and here are the things that I changed in order to get the same values from the Inspector and the Picker.
Edited by galagast
thanks a lots for this information i tried your method but it's still not working with some area , i'm trying to tweak it and i'll post the result , thanks again :)
