Rigid Body And Wire....CONSTRAINTS!....
I am trying to create a simple scene where balloons are tied together to an object using wires.(like in the movie “UP”)..
Im having balloons as packed RBD object and the parent point(where balloons are tied) as a separate rbd object.
and having wires also into the DOPnetwork as wire object..
Initially I dint simulate the wires but used the wire lines as a constriant network from SOP and made a spring constraint between balloons and parent using the wires as a constraint net, And It worked Perfectly.
Now I am turning the wires into wire object and trying to constraint the top of the wire to the balloons and bottom to the parent object, I am having matching @anchor_ids on wires and balloons.. But It doesnt work properly. If someone can explain how to constraint wires with rbd , It will be very helpfull for me.. And if someone already have a scene file for related to this please share it , Thanks a lot in advance..
Edited by Mohanpugaz
