Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Sign in to follow this
Followers 0
samvac
Fuse points
Hi there,
I'm having difficulty, getting points to fuse together, so i can export to c4d and do a sweep nurbs on it ! is there a way to do this so that i get continues sweeps, as i want to have them grow over time, at the mo I can only get it to export as individual sections.
Hope that makes sense
Thanks
POINT_FUSE.hip
Edited by samvac
readability
Share this post
Link to post
this looks very interesting - what would this look like? i.e. what do you want fused. Can you draw on a screen capture or post a finished example. thx!
Share this post
Link to post
You can't have multiple curves in one shape, I think you need to create a hierarchy with the different curve objects.
This should work, can't test it as I have a non commercial version of Houdini at home.
POINT_FUSE_should_work.hipnc
Share this post
Link to post
Thanks you for your help, really appreciate it :)  but It didn't work,  i have come up with a work arround within houdini, by checking autojoin creases in the cookie cutter it applies uniform numbers to the points, which means i can use a carve node to have a poly wire sweep on over time, which is the what i wanted to achieve in c4d.  see attached
Thanks again
Sam
POINT_FUSE_should_work_02.hip
Edited by samvac
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
