Attrib Transfer v. Attrib from Vol?
Often when I need to set an attribute by the shape of another object I do so with a point cloud and then transfer a color component to the target attribute. It works and there are a lot of tutorials that do it this way,
I was thinking though that the attribute from volume sop would also work.
Assuming that volume resolution and point density were similar, is one any less costly that the other?
