TIP: Easy installing Renderman on Windows
After downloading and installing Renderman to its default location, the simplest solution is to put following lines into your Houdini.env as well the Rmantree as a seperate entry in your System variables and appending the path with the @Rmantree. But! in the path variables of your System use $ instead of @. Forward slashes are valid for all three targets.
RMANTREE="C:/Program Files/Pixar/RenderManProServer-21.2"
Path=$PATH;@RMANTREE/bin
Thats it.
Cheers
Edited by Follyx
  • Like 2
  • 4 weeks later...
  • 2 months later...
@arumugamb
Try adding these lines in your houdini.env
My houdini env looks like this:
RMANTREE="C:/Program Files/Pixar/RenderManProServer-21.3"
PATH=$PATH;$RMANTREE/bin
HOUDINI_DEFAULT_RIB_RENDERER=prman21.3
HOUDINI_VIEW_RMAN=prman
Then my windows system environment variables look like this
Variable:
RMANTREE
Value:
C:\Program Files\Pixar\RenderManProServer-21.3\
and make sure you edit the rendermn.ini file to recognise houdini:
/displaytype/framebuffer          houdini
  • Like 2
