cone twist constraint relationship
huge
Hi everyone!
can't figure out why my cone twist constraint collpase at frame 2..., apparently this constraint dosen't care about restlength like other constraints...
i tried all constraints, everything is just fine exept with this one, and cone-twist is exactly what i need....
I join a simple file based on a SideFX sample scene turned into what i need...
thanks by advance
Cheers!
Twist-Const-Restlength.hip
Something I learned with constraints is that it's always (!) good practice to put a facet sop to unique points and a primitive sop and zero the scale. I also changed the Max Twist in the cone con. dop to 180, so it can twist freely
  • Like 3
