Normal Alignment Using a Target Curve
FruehBird
I am trying to mimic a rail spline like you would use in Cinema4D. Essentially I would like each point normal to look at the point with the same index on another curve.
From what I've found on getting a direction from two vectors is to simply subtract B from A. However, this does not seem to be the case. (See attached file)
Is there more to it than simply subtraction?
Align_Normal.hip
