RBS SIM
akarim770
Hi ,
i use Houdini apprentice 15.5 for 3 months now and i have a problem with the RBD collision.
In fact, i'm doing and exercice and the goal of the exercice is to have realistic mouvement when the tube push and object on the table. But the collision of the RBD Objects with the ground is not realistic. The thing is watch tutorials and i reproduce in an empty scene the tuto and it works fine with a simple object like a table and a cube, i mean when the cube is put onto the table the cube does not pass through the table. But in the scene you see bellow everything was working fine until I apply the glue node onto the bowl. After that the bowl the dinner plate and the waterglas pass through the table and it is the first issue i have.
Secondly when the objects fall onto the ground the collision is not realistic.
I need some one help to fix this problems.
Thanks you
