Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Sign in to follow this
Followers 0
caskal
Add FEM to animated object? (mixamo fbx)
Hey guys,
I tried to import a fbx from mixamo (walking animation) and wanted to add some fem, but as soon as I add it the walk animation stops, there is a way to have both things?
Thanks!
Share this post
Link to post
Use import taget geometry on solid object node.
And you can use pintoanimation parameter to pin exact points if you want to.
1 person likes this
Share this post
Link to post
Thanks Janis, I dont know if im doing wrong but I went into the dop network and selected the animation fbx but keeps falling (because of fem) without taking the fbx animation, here is the scene and the fbx if you can check out would be great, thanks again
fbx_to_fem.hipnc.hip
running_inPlace_Mirrored.fbx
Share this post
Link to post
Hey,
From your print screen i can see you have attached it but kept the 'target stiffness' at zero. Bump it to something like 10000000 and you should start seeing your geo trying to match your animated ref.
It describes how much will your sim geo gonna try to match the target geo.
Hope it helps,
M
1 person likes this
Share this post
Link to post
3 hours ago, msyugo said:
Hey,
Hope it helps,
M
GENIUS! thanks so much, finally got this working, cheers!
Share this post
Link to post
Marcello is right  Increase target stiffness. Plus in your setup your target geo is changing topology all the time.
You should put timeshift node with $RFSTART and  then use point deform to make this move with the animation without changing topology.
1 person likes this
Share this post
Link to post
Thanks @cudarsjanis , I will try that tomorrow in the studio, I got it working with the stiffnes but it went everywhere. My main goal here is have the man running, but add some jello like to make it weirder, to add more movement.
Thanks both for the tips, will see if I can make it work properly tomorrow
Cheers!
Share this post
Link to post
Okay I give up, been reading houdini help, watching other tutorials, testing and failing, at least I learned how the pintoanim works and I now can stick points so they dont deform. As for the fbx walking animation with fem, either I get the fem falling, or the animation without fem moving, tried with creating a group of points with pintoanimation, result was a superdeformed mesh, changed that to primitves, the guy moved but without fem. Changed target stiffness to evernumber, either started to float on the air randomly or weird stuff.
At least I made a weird animation haha
Edited by caskal
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
