Connecting points based on max distance
Hi there!
It might be a super easy thing what I'm asking, but I can't find the solution. So a I scattered a lot of points on to a geo, and I want to generate lines between the points, but only if the distance between those n number of points lower than x. I tried write it in wex based on the help, but I couldnt get to work. It might be super easy, just I'm over complicate it. Help would be very much appreciated. Thanks!
int nearbyPts[], pt, connectingPrim;
nearbyPts = nearpoints(0, v@P, chf("range"));
foreach(pt; nearbyPts)
	if(pt <= @ptnum)
    	continue;
    connectingPrim = addprim(0, "polyline");
    addvertex(0, connectingPrim, @ptnum);
    addvertex(0, connectingPrim, pt);
Did that from the top of my head, but I think that should work for you.
copy paste it into an attribute wrangle running over points.
  • Like 2
