Hey guys,
I would usually do this easily with a Copy Sop (Copy to Points now), just like on Rohan Dalvi's Mograph Series but, since the fragments are not over points, I have no idea on how to do this without a stamp.
Here's something very similar from what I need, it's just rotation and scale of the individual pieces:
Thx,
Alvaro
Edited by ParticleSkull
https://www.sidefx.com/forum/topic/27585/
At the end of that sideFX thread it describes how to access the prim intrinsic information.
You could also calculate a centroid point, then make your orientation transform, pscale and animation, which you would then then transform geometry to.
Edited by trzanko
Primitive sop can definitely help here.
If using the copy/transform points method is the way you want to go, forgot to mention it but to calculate the centroid you'd do:
vector min, max;
bbox(0,min,max);
addpoint(0,set(lerp(min,max,.5)));
there's your centroid point. hope this helps.
-Tighe
Edited by trzanko
