How to find the rotation angle through 'w' attribute
Isn't v@w rotational velocity?
If so I don't think you can determine the angle. I mean the angle is the current angle plus whatever v@w is currently set to. Just like you can't find a location just using v@v. It will always be based upon the current location modified by the attribute.
Thanks for your answer.
I want to put each piece into a sparate Geo.Intend to turn the movement of the fragment into a key frame of the Geo layer set.Function like Thinking Particles of export.
