vel shall ony affect areas where streamers are
Hans Peter
hey,
I want some curl noise to affect my flip particles which works. I also want only the actual vel streams to affect the sim. Unfortunately everywhere the volume box is present flip gets affected. An easy solution for this? Only happens when I add noise to the vel field.
untitled.hip
Edited by Heraklit
Check out Stefan's Wind Tunnel tutorial. By using two SourceVolumes you can separate density from velocity and gain a little more control. Each SourceVolume can come from a different shaped geometry. Maybe what your looking for..?
