Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Sign in to follow this
Followers 0
michaelb-01
Parameter - force evaluate expression
If I have parameters on digital assets that are expressions I sometimes find it useful to have another parameter that shows the result of the expression. I can obviously middle mouse on a parameter to show the evaluated result but is there a way to show the evaluated result by default?
I feel like the answer is no so my solution would be to use callbacks for any parameter that affects the expression then update the 'result' parameter as a raw string, unless anyone has a better suggestion?
Share this post
Link to post
You can left-click on any parameter in Houdini and that will toggle the display between the expression and the result of the expression.
Share this post
Link to post
I know, I was just hoping to be able to show a parameter in its 'result' state by default - without having to click on it first. Just in case I make an asset and another artist might not know you can toggle between the expression and the result of the expression
Share this post
Link to post
An expression field is always green to remind you that you can click to reveal what is driving the result.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
