Sign in to follow this
dcmarriott
Weird Car Paint Behaviour with Subdivision
Hi all,
I'm trying to use the Car Paint Shader in Houdini 16.
It appears to be working fine on polygons, but if render as subdivisions is turned on the material doesn't render correctly.
The image attached shows the problem, the tori have the same material, but the right one has render as subdivisions activated.
The issue doesn't occur if I subdivide the geometry with a sop.
Is this a bug I need to submit, or am I doing something wrong ?
Cheers,
Dan
carpaint_subd_problem.hiplc
Share this post
Link to post
It seems it might be a bug, but if you change the Coving setting to "Coving for all primitives" it appears to work.
Perhaps submit it as a bug?
Matt.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
